A Quick Lowdown on Sex Dolls Right Now- No Hype Just Facts
Best Blonde Sex Doll Guide- Everything You Should Know Prior To Shopping For
So you're thinking about buying a blonde sex doll. Perhaps it's the classic look, with the platinum hair, glowing blue eyes, and that evident Playboy energy. Or perhaps you're looking for something more romantic, with hair that is sun-kissed and has a charming smile. Either way, you've landed here since you've figured out that blonde does not just refer to a color of hair. It's an entire vibe.
Really? There's a reason why blonde dolls have always been among the most sought-after. They're beautiful in their photos, style up or down depending on your mood, and they provide an extra brightness to the space that darker dolls do not have. But before the click "buy," there are a few things that you need be aware of. The things that matter when the box arrives and she's sitting (or lying) at your sofa.
This article will discuss the factors that make a blonde doll distinct, and why the material preference is more important for lighter skin tones, ways to prevent her from becoming a dust magnet, and the reasons beautiful blue eyes may require some extra care. Let's get started.
A Blonde Aesthetic: What Makes Her Different
Let's face facts, a blonde doll isn't merely a doll with yellow hair. The entire style changes.
The hair itself is an obvious place to start. Blondes come in every shade from platinum ice to honey gold as well as dirty and smoky blonde. The thing is that different shades of brunettes create totally different moods. Platinum describes "glamour extravagant, costly, untouchable." Honey blonde says "approachable, warm, girl-next-door." Strawberry blonde edges into redhead territory by way of a amusing twist.
The eyes generally follow. Bright blue is the classic blonde combination, however green, hazel, and even gray can be a great match. The contrast of dark eyes and blonde hair gives a soft, spacious appearance that is inviting.
The tone of the skin is where it gets a little tricky. Most blonde dolls have fair or porcelain skin. That light canvas appears gorgeous when paired with blonde hair. Think Marilyn Monroe, Brigitte Bardot and that glimmering Hollywood glow. But, skin with pale hues is the most vulnerable to staining and is the most unforgiving with lighting, and the fastest to display dirt.
The body proportions vary widely. Blonde dolls aren't locked into one type of body. There are a variety of sizes, from petite flat-chested blondes to curvaceous bombshells sporting great hips and big boobs. The hair color is the continuous-the body's color is up to you.
An important thing to remember is that the "blonde" style often leans to that "fantasy" or "glamour" camp. It's less about the real world and more about embodying an archetype. It's fine, it's part of the appeal. Be aware that if require a lot of realism, you might be better off with a brunette or Asian doll. Blonde is all about presence an individual character, and the unmistakable star quality.
There are a lot of guys fall for it, particularly when they are looking for bigger blonde dolls sporting full curves.
A blonde doll with large frames and curvy boobs around 165cm, can easily weigh between 38 - 45kg. That's an extremely heavy object you have to carry, move and wash. If you have a weak back or you're not adept at lifting weights that's going to be a problem.
Let's deconstruct it:
- 140-150cm petite: ~25-30kg. Easy to manage, excellent to use for novices.
- 155-160cm average: ~30-38kg. This is manageable for a majority of men.
- A height of 165cm or higher, or BBW: 40-50kg. The weight is incredibly heavy. Take a look at what you're signing up for.
The "test" is very simple: Take a 25kg bag from dog's food. If it's difficult go with the smaller dolls. If you can throw it around, you're good with most alternatives.
Let me offer a piece of advice specific to blonde dolls as the look often appears glamorous, there's a temptation to go for the size of a bombshell that is 165cm+ with large and sexy boobs. That's what you can see in these photos. However, the pictures don't show you struggling to move her from the bed to the storage space at 2 am. Be realistic about your physical limits.
TPE Tpe Vs. Silicone: The $500 Question (Blonde Edition)
With blonde dolls material choice is even more important than is normal. Here's why.
Pale skin shows everything. Rust, creases and marks from wear are visible as a sore thumb against fair skin. Also, TPE because it is porous can be stained. The black dress you'd like to put on her? If it's on an TPE blonde doll, it's likely to leave marks. On a silicone doll? The risk is lower.
The feel difference is the same, TPE is generally softer and warmer. However, silicone is stronger and more durable. If you're looking at a blonde doll, it is also important to think about how your material is able to hold fine-tuned details.
Silicone catches sprayed veins delicate skin textures, and delicate facial contouring that is much greater than TPE. If you're purchasing a blonde doll because of her eye-like blue eyes, those soft smiles-silicone are going preserve that facial detail for longer.
There is a price difference. Silicone can add $500-$1,000 to the cost. For a blonde doll I'd suggest it's worth the cost. The stain resistance alone can save your heart, and the durability ensures your investment will last longer.
In the case of hybrids, this option (TPE body plus silicone head) is the ideal solution for most customers. You will get the softness where it matters and a premium facial detail where it matters most.
The Skin Tone Trap: Why Pale is a Double-Edged Sword
It's the truth that nobody talks about when it comes to blonde dolls.
The beautiful, pale skin that seems so stunning on photos? Under warm lighting indoors, it could appear washed it appears ghostly, eerie, or slightly blue. There's a stark contrast to the vibrant hair and the pale skin is visually stunning, but it's also unforgiving.
Your lighting plays a role. If your space is filled with warm yellow bulbs then your blonde doll will appear different from what she was in the studio images of the manufacturer. It is worth think about the place she'll live before you finalize your color choice for your skin.
Staining can be an absolute nightmare. Skin that is pale can act as the perfect sponge for dye. Cheap fabrics, dark clothes and even colored blankets could leave permanent marks. For a doll with a darker color, you might not notice. For a blonde doll those stains will haunt you.
Dust and dirt are visible immediately. TPE is tacky even without regular powdering. The tacky texture attracts dust. If you look at a doll with a pale complexion, dust is evident right away. You can't hide it. It's a good idea to be more vigilant with cleaning and powdering than you would with a doll that is darker.
Pro tip: If your heart is set on an blonde doll, think about choosing a lighter skin tone-"fair" instead of "porcelain." It's more accommodating and looks more natural under a variety of lighting.
The Skeleton: It's More Than Just About Posing
This is an important one particularly if you're purchasing the doll of a curly blonde.
The skeleton is the frame which holds everything together. There are two main types:
A standard skeleton employs wireframes and bolt joints. It's adequate for sitting and standing. But with time, joints get looser. Your doll can develop "floppy arms" which means she is unable to hold her pose. This is annoying and limits your options.
Advanced/yoga skeleton uses high-quality locking joints in stainless steel. They snap into place and remain in place. You are able to position her sitting up while leaning forward or standing with her weight shifted-whatever you require.
The reason this is important for blonde dolls: If you're buying an oversized or curvy blonde the extra weight places more strain over the structure of the doll. A skeleton of standard quality is likely have a greater chance of failing faster. The yoga skeleton is definitely worth the upgrade.
It's important to know that some skeletons include Ratchet joints (clicking locks) while others have friction joints (tightened screws). These joints are more durable. The seller should inform you of the type the doll has before you buy.
Factory Photo Vs. Reality: The Blonde Gap
Here's a truth bomb: the doll in those studio shots and the doll who arrives at your doorstep are identical doll. However, lights, angles and Photoshop make them look like completely different dolls.
Blonde is particularly susceptible to this. The hair's color changes in different lighting. The light skin of the pale complexion reflects light differently. Its blue eyes, which appear amazing in softboxes for studios may appear flat when lit by bedrooms' LEDs.
Always search for user-submitted photos at forums, Reddit for instance, as well as in the review section of the vendor's website. These are real photos from customers and are the most reliable way to determine the actual quality of the product you're purchasing.
Be aware of the hair. In photos taken at the factory hairstyles, the wig is generally absolutely new, perfectly styled and shot in ideal conditions. However, wigs do tangle occasionally, shed a little and then lose their shine over time. Find a spare or two to change them.
Eyes, Wigs And Makeup: Blond Head-Swap
One of the greatest things about blonde dolls is the way it is possible to change her appearance through a handful of swaps. Change from a platinum bob towards a honey blonde ponytail, then she's a whole new partner.
The wig trick is to always hold the head securely with one hand and pull the wig up over and over the hairline. This stops the strap in catching and breaking the glued-on eyelashes.
Eye color matters. Blue is the most popular blonde color, but hazel, green or even grey create different appearances. Get a few extra eye sets, then change them according to your mood.
Hair: the blonde look usually calls for more defined makeup eyebrows, pink lips and a touch of blush. Pens for makeup work best on TPE. Liquid lipstick smears. Oil-based products last longer.
Movable Jaw in contrast to. Fixed Mouth: What's Different?
This may appear as a minor thing, but it has a huge impact on the face.
Fixed mouth: the jaw is sculpted to close. The facial expression is constant. Perfect for sleeping or display poses.
Mouth that is movable is opened. It's when it's open the cheeks move backwards while the chin droops and the nose's angle changes. The woman's appearance can be quite different, even significantly different from the closed-mouth factory photos.
If you're shopping for the doll with blonde hair for that soft, charming smile, then you need Fixed mouth. The jaw that moves is meant for specific applications where its functionality will be more important than preserving the particular expression.
Hard Hands Vs. Standard Hands: This Is The Broken Finger Problem
This is the thing no one thinks about until their doll's finger is loose.
Standard wire hands The wire is thin and slender, wrapped in soft TPE. They bend for pose but snap after 10-20 bends. If the wire breaks, the finger goes floppy-no quick fix.
Articulated hands Finger joints made of stainless steel. Better, more stable posing and allow you to hold things like glasses and props.
It's a $50-$100 upgrade. For a blonde doll, it's worth it since the doll will likely be photographed more (blonde dolls can be photographed) and the poses for fingers are crucial.
Let's be honest about the amount of time we commit to.
The fun portion could last 20 minutes. The clean-up can take up to 45 minutes if you're doing it right.
1. Remove and clean the insert with antibacterial soap.
2. In order to make holes for built-in plumbing, you need an specialized shower with moderately warm water and a gentle soap wash.
3. Incorporate drying sticks and allow for about 15 minutes. It's crucial to not do this or you'll see mold.
4. The entire body is coated with baby powder or cornstarch. This stops the TPE from getting sticky.
Removeable inserts are a lifesaver. They reduce cleanup time by half, and also prevent the growth of bacterial colonies within your body. If you're just beginning, definitely think about inserts.
This is the number one blonde doll mistake.
Dark colors-particularly black, dark blue, and purple-infiltrate the oil of the TPE. If you have pale, blonde skin those spots are permanent and apparent. There's no fixing them.
The test: grab an uncolored white cloth, soak the cloth, then rub it on the fabric. If any color gets transferred are visible, you should not put it on your doll.
The solution is to Get dark-colored clothing cleaned 3-4 times in hot water and white vinegar to make the dye set. Keep it to light shades. White, pastels or beige are all safe.
How you store her effects how long she lasts.
Hanging is the best choice. It helps maintain joint tension and prevents flat spots. The ceiling needs a powerful hook or purpose-built storage closet. Hang only by the designated shoulder loop, not by the arms or neck.
It is a good option, but it comes with disadvantages. It puts pressure on the buttocks and places pressure on the skeleton joints. If you choose this option choose a flight case or a clean space.
Squeaking joints? Happens with lying down storage. A tiny drop of lubricant made from silicone on the joint's bolt is enough to fix it. Never use oil-based lubricants on TPE joints, as they can degrade the materials.
The feet of standing have bolts made from metal inside the soles. The doll can stand on her own. This is essential for photographing, display also shower use.
Standing feet aren't bolted. Soft TPE can bend or tear if you try to lift her.
Shower safety: if you put a non-standing doll in the shower, water dripping into the foam that is exposed or the foot's metal leading to rust, which then travels up the leg skeleton. In a few weeks, her legs don't move. Don't do it.
If you are planning the privilege of showering with your brunette girl and stand, feet must be on the floor.
Insert or. built-ins: Hygiene Debate
Built-in has a more realistic feel. However, cleaning can be a hassle. It is a chore to get rid of water, drying is a lengthy process, and mold danger is real.
The removable inserts have a visible seam. They are however superior in terms of hygiene. They can be cleaned in the sink, air-dry the entire time, and then change them once they've worn out.
For blonde girls with pale skin, the benefits of good hygiene can be even more important. Odors and stains are more visible on light skin. Inserts help you keep everything tidy.
Before signing the delivery receipt, inspect the box. If it's damaged or crushed Take a picture of it. Then, you can open it and inspect:
- Are there tears in the armpits, groin, or neck?
- Bolts for the standing feet (if the case) present?
- Head sculpt that is in line with the factory photos?
- Joints moving smoothly?
If you sign for a damaged box, only to notice a tear, shipping company denies the claim. Your claim is void. Be sure to take a photo and inspect everything prior you sign.
Hair over the face The hair can be altered. The face is always there. Choose a person you love.
Don't pay attention to weight: Purchase the doll that you can actually hold not the one you think best looks in photos.
Do not skip the articulated hand: Damaged fingers can ruin your look. You can spend the extra.
Forgetting about stains: Pale skin is a clear indicator of everything. Be obsessed about testing your fabric.
Don't bother with the powder routine: TPE without powder is sticky and attracts dust. On blonde skin, that dust is visible. Don't skip it.
A blonde doll adds some brightness to your life. There's no doubt about it. That hair, those eyes, that brightness. It's that special energy more dark-colored dolls don't have.
But she's also more work. The pale skin needs additional treatment. The hair requires regular maintenance. The whole aesthetic requires more attention to small details.
If you're willing to invest the effort? She'll give you. A well-maintained blonde doll is stunning appealing, beautiful, and inspiring to have around.
Do it with your eyes wide. Be aware of the stain risk. Consider the weight. Plan your storage. When she will arrive? You can take your time opening of your box, loosen those joints slowly, and enjoy the experience. It's worth it.
